@rhyde avatar
gts300ie
@rhyde avatar
gts300ie
hi all just wondering the above, as all my other bikes the throttle snaps back, but my 300gts doesnt, kind of slowly rolls back, ie its not a snap
what should it do?
@raputtak avatar
@raputtak avatar
All of mine have rolled back quickly, not a snap, enough to slow the bike abruptly.
Yours makes it easier to do hand signals.
Over time, the throttle grip can begin to bind on the bar-end weight. Easily cured - add a washer between the bar-end weight and the handlebar.
@rhyde avatar
gts300ie
@rhyde avatar
gts300ie
cheers guys
@blackmoon181 avatar
LX125 (in bits) , Honda sh300i & NC750x
I imagine its the same on most cable throttle designs but on the BV350 there is an adjustment screw under the pet carrier where you can increase the 'return' tension and make the throttle snap back quicker.
Washer idea is good and i've used before to put less stress on the cable.
@rhyde avatar
gts300ie
@rhyde avatar
gts300ie
is there one on the gts300 if so where do i locate it
@juspa avatar
GTS 300ie ABS 2016
@juspa avatar
GTS 300ie ABS 2016
I'm seeing the same problem, except the throttle doesn't really return back at all. I'll try the washer idea and report back if it helps.
@capt_gary avatar
2010 Vespa super,2016 vespa 3 00 1979 p200 with sidecar 1958 cu shman eagle with sidecar Inder trai ler 1983 bajaj tuk tuk tristar 2018 royal Enfi
@capt_gary avatar
Jims idea works
Jim did not get to be the resident curmudgeon by accident he has seen the movie and got the tshirt this is coming from an auxiliary curmudgeon. Capt Gary
@mike_holland avatar
GTS300 Super 2023 Beige
My old GS150 throttle used to stay put, which was great for riding no hands, but that would be dangerous with an automatic 300 cc scooter.
@juspa avatar
GTS 300ie ABS 2016
@juspa avatar
GTS 300ie ABS 2016
Washer did the trick. Seems to be a bit of a bad design for rainy locations. Vespa is back in full working order.
[ Time: 0.0088s ][ Queries: 3 (0.0017s) ][ live ][ 341 ][ ThingOne ]
