It will also depend on how aggressive your pads are. I run a more aggressive pad so I get squealing out of mine but they are better for reducing brake fade when riding more aggressively. Especially at higher speeds.
Sometimes anti-squeal grease doesn't do the trick. In which case you can make anti-squeal shims which will definitely cure it. You can also buy pads with shims already attached, but they don't seem to be very common.
