vespa gts250
vespa gts250
so i found this today in my bike while poking around, its stalled every now and then, and i dont know what this thing is, or if its cracked or if it normally looks this odd. it seems like that used to be a full hose
vespa gts250
vespa gts250
ok just looked it up after an hour and it appears to be an evapectomy of sorts. which would explain why its ran 6 months like that?
can anyone confirm?
actually this would probably explain why it dies every other month once, a day or on the same day its fueled up(and overfilled half the time, i didnt know!!!), starts back up and is fine for another 1000 miles. sheesh it probably wouldnt start back up if it wasnt cut too.
@mjrally avatar
@mjrally avatar
It looks like a valve in the EVAP system. Is that the charcoal canister above it?
vespa gts250
vespa gts250
I think so, I'm absolutely certain at this point. Will this cause it to stall? I heard of people cutting these things out on purpose, do I need to get it fixed?
@mjrally avatar
@mjrally avatar
Yep! The vacuum lines go through the EVAP system and the carb, fuel tap, SAS all are affected. I've read all about it on here but didnt' get to experience it firsthand until last month. Removing the EVAP lines seriously was a night and day change.
vespa gts250
vespa gts250
so get it fixed or leave it as is? is the cut causing him to stall? if so at least i finally know!
@mjrally avatar
@mjrally avatar
I don't know the GTS EVAP systems enough to definitively say yes or no. However, since it's just a small piece of hose and how badly I've seen an engine run with a faulty EVAP system, I'd replace that small section of hose. Pull the old stuff off and see if you can buy new stuff by the foot at an auto parts store and jam it on. Won't hurt anything.
vespa gts250
vespa gts250
suppose i can just re-cut it if it doesnt work lol. can i just duct tape it?
@mjrally avatar
@mjrally avatar
Nope. Duct tape won't seal it enough for the vacuum that goes through it. Gotta replace it. Vacuum line from the auto parts store is cheap.
[ Time: 0.0109s ][ Queries: 4 (0.0042s) ][ live ][ 313 ][ ThingOne ]
