Vespa ET4, Stella 2-Stroke Manual
Hello,
Long time lurker, first post. I've read countless threads on this and other websites, and I've begun working through the suggestions. I'm hoping that my most recent symptoms will help someone point me in the right direction!
2002 ET4 150cc, had tuned up a couple years ago by a scooter mechanic (cleaned carb, new plug, oil, etc.). My wife rode it once or twice and it has been sitting in the garage.
I bought a new battery and installed. All lights and horn work properly and immobilizer light goes off when key is turned. Upon start I would just get a single click from the starter relay. I used sandpaper to clean up the metal tabs of the relay and the connections at the battery. At this point, the scooter tried to start once and then went back to the click. If I tapped the starter motor lightly, I could get it to try to start, but it never turned over or started the engine. I assumed I needed a starter motor, from things I read online.
I installed a new starter motor today. I put a bit of Sea Foam in the tank and added more gas (there was some sitting in the tank for a long time, unfortunately). When I reassembled, I got a strong effort to start, but it still didn't turn over. Strangely, the dash lights started to dim after only holding the starter button for a couple of seconds. The battery is brand new.
Now all I'm getting is a buzzing/spinning sound from the starter motor when I press the start button.
I've toggled the kill switch, tried each brake lever when starting.
I did try the kick start about a dozen times, but I've never once had even the slightest indication that the scooter was going to start with it. My Stella, on the other hand, will start with the kickstart on the first kick even if it's been sitting for a year!
Hopefully this makes sense and I haven't forgotten anything. Any help would be much appreciated.
PS I'm attempting to attach a .MOV file that would allow you to hear the sound that it's making when I try to start, but I don't know if it will work!
BV400, Primavera 150
Joined: UTC Posts: 4874 Location: Twin Cities, Minnesota
Could be the battery, even tho it's new. Did it have a good charge when you put it in? Also, try cleaning the battery terminals.
Good luck & have fun! 8)
ET4 Won't Start - Video With Sound
Trying to post link. Remove the spaces?
https:// youtu.be/ o0AKnJccOzQ
Thanks for the reply, JKJ. Battery tested fine when I bought, but I'll attach tender and check with a tester again. The terminals are freshly cleaned, but I'm not opposed to re-cleaning, re-checking...
Vespa s 125 ie 4t
Vespa s 125 ie 4t
Have you cleaned the Bendix? If it clicks and just spins it sounds like the little pin in the starter isn't swinging out and engaging.
Knight, I had to look up the Bendix and read a bit about it. I've got the battery on a tender and if the fully charged battery gives me the same results, I'll try to gain access to the Bendix and clean.
I didn't do anything special when I slid the new starter motor in and secured it. At first it didn't slide in, so I gently rotated it until some firm even pressure slid it into place for me to bolt it. Hopefully there wasn't something else I needed to do, relative to the Bendix.
Off to look for a tutorial on cleaning the Bendix...
Vespa s 125 ie 4t
Vespa s 125 ie 4t
Good news! After leaving the battery on the tender for several hours, the starter was able to engage the engine. After a few tries I got it running. Barely. It finally ran for about a minute. I can get it to start but it'll die after a few seconds now. But that's progress. I'll leave it for awhile and keep coming back to it. Hopefully the gas and sea foam will work through anything that's causing it to die or struggle. Maybe?
How much old gas was in the tank? You mentioned you added fresh gas but hold old and how much was in there?
1980 P200, 1974 90/100 smallframe, 1972 primavera (under construction), 1974 kawasaki F7
I agree with MJ. Maybe dump out a tank of gas and put some fresh gas in and see what the outcome is. For a few bucks...worth a shot.
I have a siphon pump that I used to pump out less than a gallon of gas. It was pretty yellow... I added a double dose of sea foam and some fresh gas and it's been starting pretty consistently, but 2/3 of the time it dies within a few second and maybe 1/3 of the time it'll idle for 30-45 seconds. It's always right on the verge of dying as its idling. I'll keep working the new fuel and sea foam through and see if there's any improvement. I can look into cleaning the carb or anything else, but I haven't done that before...
Joined: UTC Posts: 9719 Location: Main Street, Watts. OK
Unless your can of Seafoam can take the carburetor out of your Vespa, remove the jets and clean them, it's doubtful you can add enough to fix the problem.
Joined: UTC Posts: 23516 Location: Harriman, Tennessee, Tn
a double dose of sea foam will not help, you need to remove and clean the carb.
I thought I'd see if I got lucky. I'll clean the carb next. Thanks for all the help so far.
