P200E (1980) and Rally 180 (1971)
I recently replaced the back brake pads. I'm having some trouble adjusting them. The brake pedal is almost to the floor board before it engages? Thanks
@shawn45 avatar
1979 P125x, 1980 P200E
@shawn45 avatar
screw in the adjuster screw all they way, then loosen up the bolt that holds the break cable at the back actuator. Pull the break cable as tight as you can and clamp it back down via the bolt that holds it. Test brake pedal again. It should be tighter now. If still a little more play then you want, you can adjust the adjustment screw out and fine tune. see how that works
[ Time: 0.0074s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
