Gts super 300 '12
Gts super 300 '12
I have the Scootwest rear led kit installed front and back on my Gts.[img][/img]
Gts super 300 '12
Gts super 300 '12
I would like to change these out for something better. Besides going back to Scooterwest, where else could I find these bulbs that will fit into the socket housings? I do shop at a site called Super Bright LEDs from time to time. That where I got my brake like modulator.
Gts super 300 '12
Gts super 300 '12
This style
2015 BV350 2007 GTS(sold) 2003 BV200
ba15s
@masala avatar
@masala avatar
946
Another site you can check out for motorcycle LED solutions is Custom Dynamics - they've got loads of stuff, but not so much for the home (like SuperBrightLEDs does).
Gts super 300 '12
Gts super 300 '12
Posts are offset on mine
@flipasaurus avatar
GTS250ie
@flipasaurus avatar
GTS250ie
If you are looking for just the bulb, I happen to be a light bulb salesman in Ohio. We stock a bulb with that single contact bayonet base. It is 10-18v I couldn't tell you what the lumen output is but I know the bulb is around $14. I can find out more on Monday if you want to pm me.
@flipasaurus avatar
GTS250ie
@flipasaurus avatar
GTS250ie
You can check the bulb out at halcolighting.com the part number is 80692
That one is a BA15S base, not a BAU15S base.
tvnacman wrote:
ba15s
No - BA15S has the pins the conventional 180° apart. BAU15S is the correct base type with the (150° ?) offset pins.
@flipasaurus avatar
GTS250ie
@flipasaurus avatar
GTS250ie
jimc wrote:
tvnacman wrote:
ba15s
My apologies everyone. I failed to inspect closely enough nor have I have my own lights out to have known this.
Gts super 300 '12
Gts super 300 '12
Bau15s is the offset type then? I've been seeing bulbs but just need to make sure they aren't too long or they won't fit in the lens housings
So it seems.
You might have more luck buying from an EU supplier.
@crazycarl avatar
2007 250 GTS, 1980 P200E, 2010 ThunderFly 190 (SOLD) 2015 Yamaha SMax
@crazycarl avatar
A quick search on Amazon for BAU15S Amber LED and I found these...
https://www.amazon.com/JDM-ASTAR-Bright-Chipsets-Projector/dp/B00XV4W686/ref=sr_1_1?ie=UTF8&qid=1474914966&sr=8-1&keywords=bau15s+amber+led&refinements=p_72%3A2661618011
Measurements from the description are 1.93" long and 0.71" in diameter.
I purchased other JDM ASTAR (switchback 1157's) for the front and I'm very pleased with the results.
BAU15S from Amazon listing
JDM ASTAR Switchback leds in my legshield, turn illuminated in this shot.   Paired with Custom Dynamics LED Amber strip
Gts super 300 '12
Gts super 300 '12
I like those bulbs shown above. Do they have the offset posts for the GTS sockets? What about the switchback 1157? The only concern I have is getting ones with the correct socket connection.
@crazycarl avatar
@crazycarl avatar
The 1157 switchback bulbs I have in the front of my GTS fit with the LED Switchback harness kit I bought from Scooterwest with no issues and went into the front lenses without modification. These won't work for the rear turns.
https://www.amazon.com/JDM-ASTAR-Extremely-Switchback-Brightest/dp/B00RV417XM/ref=sr_1_4?s=automotive&ie=UTF8&qid=1475095055&sr=1-4&keywords=1157+switchback+led
For the rear turns, the BAU15S bulbs are listed on Amazon at the link in my previous post.
Gts super 300 '12
Gts super 300 '12
Ok I'm thinking about putting a set of white in the front and a set of amber in the back. Anyone think this setup would be too distracting having whites in front? I'm not getting the switchback kind just standard.
@bean_counter avatar
2016 BV350 White
2016 BV350 White
The amber ones in the back would be fine. However, I'm pretty sure that having white ones on the front would not be street legal. Put amber ones in the front too or get the switch back kit for the front.
I have the SW kit on my LX and love them. What's wrong with them?
[ Time: 0.0114s ][ Queries: 4 (0.0021s) ][ live ][ 313 ][ ThingOne ]
