I'm going to be swapping out my GTS's Exhaust Gasket this weekend. In the meantime I still have to get to work. I ride a little under 40 miles each way, taking about an hour a day.
The low grunt noise of the gasket slipping seemingly happened overnight but after a 2000 mile roadtrip. Generally I'd hear it pop a little after I slowdown from a long run but it just happened one morning at startup. I did a quick inspection and it doesnt seem loose per se, just the gasket inside is clearly going.
My question is are there any roadside remedies to help avoid any problems between here and the day I fix it. Make-a-gasket type stuff from Autozone. Something that wont cause a problem when I remove the exhaust in a couple of days either.
LMK. Thanks. Keep Scootin.
