LML Vespa 125
LML Vespa 125
Hi, I've had my 2011 LML PX125 for 9 months and it's run fine. On Friday I used the 'reserve tank' fuel supply for the first time. On the way home I filled it up. Today it kept cutting out without warning. It would be running fine, then cut out. At first I went about 2 miles before it cut out first. But now it does it after a couple of hundred meters. I'm assuming there must be dirt in the fuel line. any suggestions on what to do about that, or what else it might be?
@bobo avatar
@bobo avatar
I'd suspect you've sucked some crud into your jets or fuel filter. Check out the link on how to get to them to clean them out.
http://www.vespamaintenance.com/fuel/carbrebuild/index.html
LML Vespa 125
LML Vespa 125
thanks for that. I'll give it a go.
[ Time: 0.0084s ][ Queries: 3 (0.0022s) ][ live ][ 335 ][ ThingOne ]
