@kamaseya avatar
'58 Vespa 150, '63 Allstate 125/177, 1980 Vespa P200E
@kamaseya avatar
Trying not to bore you with details, so here I go.
I picked up a 1980 P200E when I was passing through Kansas City 2.5 years ago ($500). It did not run. But the price was right so I took it home to Jacksonville FL.
The last owner said it was running before he got it on a trade. He suggested it might be electrical issues. The Vespa is complete. I haven't yet worked on it. That time is about to start.
So the Question is; Whats the completion range for a good cylinder? The Vespa has about 10,100 miles on the odometer (which means nothing).
Thanks for the info.
@pdxjim avatar
2005 PX150 In a Part-time Relationship with a 2-Stroke Vespa Since 2007
@pdxjim avatar
Minimum is around 100psi, which isn't good, but less than that and it probably won't even start.
When you get started on it, check for spark first. If you don't get any, come back here. We'll get you going.
@kamaseya avatar
@kamaseya avatar
My P200E Thanks you...
Thanks as always, I will get back with you if it don't start.
[ Time: 0.0075s ][ Queries: 3 (0.0015s) ][ live ][ 335 ][ ThingOne ]
