@calcobrena avatar
2016 GTS 300 Super
@calcobrena avatar
2016 GTS 300 Super
So... I wanted to attempt to change the back tire by myself. Will there be any issues because of the ABS? Does anyone know a good video of someone changing one with ABS?
Manual has some warning about doing anything with the tires because of the ABS...
Thanks.
@piekilla avatar
2021 gts 300 supertech
@piekilla avatar
did you change the tire, if so did you run into any problems? Looking to change tire valve stem and requires removing tires.
why are you changing the valve stem?
@lebo avatar
@lebo avatar
My understanding is you have to re-calibrate.
@piekilla avatar
@piekilla avatar
It has the rubber stems I want to use metal stems
@lebo avatar
@lebo avatar
Why, so they can get corroded? Don't bother.
@piekilla avatar
@piekilla avatar
Rubber also degrades with time, but i want metal so i can have a tpms. And yes I'm lazy so i wont check my tires every ride if i have to do so manually. so this way i only have to do manually maybe once a month just to make sure tpms is correct.
the metal also have rubber seals and those fail quite often. standard rubber valve stems have a great life and I normally change them every other tire change for folks, which tends to be 2 years.
good reliable TPMS systems typically install inside the rim and have nothing to do with valve stems,
by checking your tire pressure on a regular basis this also gives you the opportunity to do a visual inspection of the tire itself.
@piekilla avatar
@piekilla avatar
in your experience how long do the metal ones last?
I do what OAD does. Use the regular rubber ones and i swap them out when i do a tire change. Rear one gets changed more often. I change the front tire every 4 yrs whether it needs to be done or not. Rubber degrades over time. We can't use the curved ones on the LX models. A friend had a rear tire swapped out by Montgomery motors and they put a curved on on. She was exiting the the airport when her rear tire went flat. Not a lot of room back there and it must of hit n something. She was lucky that it happened them. SHe went via the freeway and was doing 60mph right before she slowed down to exit at the airport.
[ Time: 0.0110s ][ Queries: 3 (0.0018s) ][ live ][ 313 ][ ThingOne ]
