Hello Fellow enthusiasts. As usual, thanks in advance. This is absolutely a wonderful resource and I value all of your opinions, experience and knowledge.
So my lovey GT200 (Victoria) and I have been getting to know each other. Among other things, I am preparing to do my first oil change (my first, not hers) and plan to take great care of her.
On to the question/issue; *All of these readings are cold tires. If it matters, outside temp was about 50 degrees Fahrenheit.
- I finally got a worthwhile pressure gauge and checked my tires. The plaque on Victoria says it should be 26.5/29.5psi front/back respectively. The Tires themselves say 41psi (max the tire can handle?). I have read here that I should go with what the scooter says and not the tire.
So I checked my tires and the reading on my tires (from new fancy gauge) was at 30/32.
So before taking it out for an afternoon spin, I let some air out ant got them down to about .5 psi above "factory" recommendations. roughly 27/30.
Keep in mind I am an inexperienced rider still learning, but when I was taking curves this afternoon, especially at speeds between 35-45mph, it felt like there was a bit of "wobble" in the front tire as I started to lean into my turn. Not drastic, but noticed it twice. Not the most fun feeling ever. I don't remember this happening before I let some air out of the tires.
Initial googling/researching tells me that this may be tire pressure related.
Questions:
1. Would you think this is indeed related?
2. If so, should I be concerned that the scooter handles better with slightly overinflated tires? Is this a sign that something else is wrong?
3. Is there any dangers with re-inflating the tires to the 30/32 area? Should I not do that? Will I lose grip in corners and such (though a wobble is worse)
Thanks all
