My 09 GTS250 stopped running in November. I was on the freeway near top speen when I lost all power and costed to the sholder. After failing to start and seeing nothing obviously wrong I sent for a tow truck.
I just looked at it and discovered that the engine destroyed itself. An exhaust value made contact with the piston, broke off, rattled around the cylender, ruining the head, punching 2 holes in the piston, and finally logging itself in a 3rd hole and welded itself to the piston. I included autopsy photos for your enjoyment.
I've several questions I haven't found anything in the forum about. Any and all ideas are welcome.
1- Has anyone heard of this happening before? Did I experience a known problem or an unheard-of failure. The cam shaft, sprocket, and timing chain looked great. So, I'm suspecting a valve spring failure due to fatigue.
2- Assuming that there is nothing to replace in the bottom end, what's the best route for parts to fix this? I haven't prices out oem parts yet. I've sceen Molissi performance kits with the head, piston cylinder, and everything needed to put them together for $575 to $875. Is this a good idea? The cylender lining is pitted and scored. It cannot be used as is. Can it be bored out or resleved? Are there OEM or aftermarket overbore pistons?
3. I cannot get the cases apart to inspect in there until I remove the oil seal between the transmission and the engine case. This requires a special tool. Anyone know how to make a tool or open this with standard tools.so I don't have to reinvent the wheel?
Any other questions I haven't thought to ask?
Thanks for any and all help!
