The bike was driveable and I took it around the block and worked fine except for continuous blinking amber tilt lock indicator. All the front fairings where damaged so I removed and at the same time I loosened the front subframe as it was slightly mis-aligned.
My problem now is that once I start the bike I get red tilt failure light and continuous alarm. I am assuming that adjusting the subframe may have caused the new issue so wondering where I should start looking for the cause of the problem?
I cannot reset the tilt lock with the double tap method so apart from finding the original fault is there a method to reset the tilt-lock?
Grateful for any help as I only have limited time to work on the bike due to work commitments and can only work on the bike when it is dry ( great British weather!!! )
So far:
New tilt lock switch
Checked both sets of fuses
New battery
To do
Clean wheel sensors
Check and clean connections ( but which ones? )
⚠️ Last edited by fungomerry on UTC; edited 2 times
