@bald_wasp avatar
@bald_wasp avatar
I've read a few threads regarding this issue but wanted some fresh opinions. My 2006 GTS will frequently have an issue where it'll surge rpms at idle then come back to normal, then continue surging. Generally if I turn the scoot off and restart it after it's run for awhile it'll idle normally. Not guessing that it's cracked hoses, although that is a possibility. Could it be a bad lambda sensor or something in the electronics?
w.
@miguel avatar
@miguel avatar
I've had that happen occasionally. Opening the gas cap and restarting usually solves the problem. I think it's a clogged evap canister. Hopefully others will check in
Miguel
@vespasfw3 avatar
2006 Vespa GTS250ie, 2004 Vespa ET4, 2022 Royal Enfield Himalayan, 2001 Kawasaki W650, 2023 Honda Trail 125.
@vespasfw3 avatar
Mine just started doing that. I'll have to check the canister. Was wondering about cracks in hoses. I'll watch this thread to see if anything else comes up.
@raputtak avatar
@raputtak avatar
We called it 'hunting'.
My lawnmower did that. The man at the shop said it was a ruptured diaphragm in the carburetor.
A totally useless piece of information for this thread. ROFL emoticon ROFL emoticon ROFL emoticon ROFL emoticon
(I am in a good mood this morning. Time to go tease the folks on Facebook.)
@bald_wasp avatar
@bald_wasp avatar
I had a 1990 Jetta GLI that did this for years. I used to call that car "Sir Revs Alot". All the German mechanics in the world couldn't fix it. Finally unloaded that pig.
w.
[ Time: 0.0085s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
