1980 P200E - GT 200 L - 2005PX150
Can someone who has done the conversion please tell me how much is a conversion disk brake from a Stella vespa for a PX, and what parts it includes.
@vintage_red_matthew avatar
MV Santa
MV Santa
The Stella brake mod is great and not too hard.You'll get a better response if you ask this question in the Not so Modern section.
Good luck.
@safis avatar
@safis avatar
Do you want a full hydraulic conversion or you can settle with a 50/50 system (less hassle, parts and money)??
You can easily upgrade to a 50/50 Grimeca system without the need to change your handlebar or have to deal with brake hoses, etc.
After you determine your axle, you can order one of those kits...
16mm axle
http://www.sip-scootershop.com/en/products/disc+brake+grimeca+classic+nt+_30005000
20mm axle
http://www.sip-scootershop.com/en/products/disc+brake+grimeca+classic+nt+_30015000
If you want a full hydraulic, it will be cheaper to buy a whole LML fork but you will also need a handlebar, a brake pump and a brake hose...
Complete fork
http://www.sip-scootershop.com/en/products/steering+column+lml+for+vespa+_62812000
Handlebar with required tube kit
http://www.sip-scootershop.com/en/products/handlebar+lower+part+lml+for_60042100
http://www.sip-scootershop.com/en/products/mounting+kit+lml+handlebar_j60042300
Brake pump
http://www.sip-scootershop.com/en/products/brake+master+cylinder+piaggio+_56378800
Brake hose kit
http://www.sip-scootershop.com/en/products/brake+hose+kit+sip+for+vespa+_30050000
@moto64 avatar
@moto64 avatar
I have to say that it is impressive when someone goes to that length to answer a question. Nice.
@safis avatar
@safis avatar
I think that's the point of a community of Vespa lovers...
Yes, thank you
@larrytsg avatar
1979 P200e
@larrytsg avatar
1979 P200e
Not sure of the prices of the above solutions, but one other thing that some people do is to be on the lookout for a trashed Stella. If you can find a Stella with a good fork, it's pretty much plug and play after doing a minor modification to the old P200 headset.....
Yes, I got a Stella set up, but decided to keep the original. Selling it, and needed an idea on the going prices.
[ Time: 0.0098s ][ Queries: 3 (0.0029s) ][ live ][ 313 ][ ThingOne ]
