I have a '65 Allstate that I am starting to get an issue with the kick starter. Every once in a while it will slip when get the right two teeth meshing that are wore or chipped. It still is working but I want to get my ducks in a row for when the parts fail and they will have to be replaced. I have nearly 6000 on the motor now and figure I might as well go thru the engine and get it all set for the next 6000 miles or longer. I would like to get the cases vapor blasted and have someone that really knows there stuff rebuild it so it is done right. Maybe even juicing up the motor a little bit in the process.
I live in Michigan, where is the best place to get the motor rebuild and what is the best way to get the motor there as I am going to assume that the builder will not be in or near Michigan.
Thanks in advance.
