Hi everybody,
Relatively new to scooters and have a question. I just resurrected a p200e after 20 years sitting. It's now running great but after I changed all the cables the clutch cable snapped after only 300 miles. I was cautious that I didn't overtighten the pinch bolt. I installed a Mallossi 4 disc clutch but used the original springs. The only thing I noticed is the end of the cable adjuster seems to be a bit offset to the clutch arm. The cable is definitely angling slightly as it comes out of the adjuster. Is this normal? Any ideas to make the next one last longer? I was thinking of soldering the cable where it gets clamped by the pinch bolt. I assume that is the weak spot?
