I searched NSM for "cold start" and scanned/read through 7 pages of results, but didn't find something quite like what I'm experiencing.
When cold starting, I pull the choke out, no throttle; bike starts on third kick just about every time, but then stalls within seconds.
After starting/revving I push choke back in and hear the revs come up a bit (as expected) but bike stalls when I let off throttle
After each stall, it starts again on next 1-2 kicks.
Occasionally when this happens, the throttle is also bogging when I rev it.
This morning I held the throttle steady and it was all over the place, then I revved higher for a bit and the issue went away. This happens every so often.
After a few starts and some revving, the issue seems to clear up, idle is fine, and I go on my way and no stalling at all. Acceleration is smooth, performance as expected.
Recent work done:
Adjusted timing with strobe and degree wheel
Stator was re-wired last year
Tightened carb mounting bolts; examined and cleaned all jets, float, needle, banjo connector & washers.
Checked for air leaks around carb box and found none.
Adjusted idle and mix screw - both are close to "normal settings"
Verified fuel flow to carb with/without gas cap closed
Stock motor, BGM Big Box exhaust, 24/24E Dellorto carburetor
I live at/near sea level.
Jetting:
Starter: 60
Slow running: 50-120
Main: 122
AC: 120
Mixer: BE4
Ideas? Suggestions?
