Tue Aug 08, 2017 9:32 am
Piaggio MP3 500
Piaggio MP3 500
Tue Aug 08, 2017 9:32 am linkquote
I have a 2010 MP3 500 that has experienced the familiar tilt-lock 5 beep warning periodically.
My dealer diagnosed the tilt-lock issue to be the tilt-lock pressure sensor, part number 640295. They replaced the hydraulic fluid in the system but didn't have the part in stock.
Trouble is that the dealer (Eurosports in Coopersburg, PA) is a 3 hour round trip for me, so I thought I could replace the part myself.
Is it just a matter of unscrewing the part and screwing in a new one? Will I have to re-flush the hydraulic fluid? Reset something on the ECU to make it all work?
I hear that this is a very common problem, but I've never seen any thread about the steps to replace the sensor.
Help appreciated.
Thanks!
Piaggio Pressure Sensor (640295)
Tue Aug 08, 2017 11:00 am
Tue Aug 08, 2017 11:00 am linkquote
It's not too difficult, but there are a few steps.
Remove the front end plastics.
Drain out the tilt lock fluid so the sensor is above fluid level. Otherwise you'll just spill it.
Remove old sensor.
Install new sensor (be sure you replace all the little washers; I think there were two of them when I did my pressure switch a couple months ago).
Pressure bleed from the bottom to fill the system. This will push any air between the pressure switch and the pump out. IF you only drained it as much as really required....
Replace front end plastics.
Tue Aug 08, 2017 11:15 am
Piaggio MP3 500LT
Piaggio MP3 500LT
Tue Aug 08, 2017 11:15 am linkquote
If I remember correctly bleeding should be on the stand with tilt lock disengaged.
Tue Aug 08, 2017 11:31 am
Tue Aug 08, 2017 11:31 am linkquote
Good point; correct.
Tue Aug 08, 2017 12:41 pm
Piaggio MP3 500
Piaggio MP3 500
Tue Aug 08, 2017 12:41 pm linkquote
Thanks for the concise summary. So, I shouldn't have to worry about any ECU resets or the like.
I know the system was just filled with new fluid, so having not done this before, could I just:
1) attach a lenght of plastic tube and large syringe to the bleed connector
2) suck out fluid as I loosen the sensor until it the fluid drops below the sensor level
3) replace with new sensor
4) push on syringe until air is expelled and a bit of fluid comes out at the sensor
5) tighten the sensor
Am I too naive?
Tue Aug 08, 2017 3:16 pm
Tue Aug 08, 2017 3:16 pm linkquote
Am I too naive?
I have a personal dislike for reusing any fluid I remove from a vehicle.
Also, it would be more difficult, I think, to avoid air bubbles.
Oh, and you need to bleed after installing the new sensor (tight); you have to push fluid all the way up and into the reservoir otherwise there WILL be air in it.
Tue Aug 08, 2017 3:39 pm
Tue Aug 08, 2017 3:39 pm linkquote
Am I too naive?
fluid is cheap, just replace.
Tue Aug 08, 2017 3:56 pm
Tue Aug 08, 2017 3:56 pm linkquote
Am I too naive?
That's a good point too.
$100 sensor.
$4 DOT4 brake fluid.
Tue Aug 08, 2017 4:54 pm
Tue Aug 08, 2017 4:54 pm linkquote
Am I too naive?
$100 sensor.
just like saving .02 Cents on a gallon of gas from the cheap station that I would not even use in my lawn mower but folks still go out of their way to save that .02 cents versus getting a top tier gas.
⬆️    About 8 months elapsed between posts    ⬇️
Sun Apr 15, 2018 12:39 pm
Piaggio MP3 500
Piaggio MP3 500
Sun Apr 15, 2018 12:39 pm linkquote
Remove old sensor.
Madison, where do you drain and fill the fluid? I couldn't find any reference to that service in the shop manual.
Sun Apr 15, 2018 12:42 pm
Sun Apr 15, 2018 12:42 pm linkquote
Remove old sensor.
Filling to top up is that container up top with the black screw-on lid. To bleed, there are bleed screws located just above and inside the wheels. I'll go get a picture and parts list link shortly....
Sun Apr 15, 2018 12:49 pm
Sun Apr 15, 2018 12:49 pm linkquote
Here is the location of the tilt lock bleed screws, and a parts list exploded drawing.
Not so close up.
Close up. The black rubber cap is off the bleed screw.
And the exploded view of the parts.
Sun Apr 15, 2018 1:01 pm
Piaggio MP3 500
Piaggio MP3 500
Sun Apr 15, 2018 1:01 pm linkquote
Wonderful. Thanks for the pics. I suppose it is the same on the 500.
Sat Apr 21, 2018 7:07 am
Piaggio MP3 500
Piaggio MP3 500
Sat Apr 21, 2018 7:07 am linkquote
Install new sensor (be sure you replace all the little washers; I think there were two of them when I did my pressure switch a couple months ago). ...
I'm up to this step and I want to do it ONCE, correctly.
I have the two washers, but I'm not sure if they were BOTH on the sensor side or one there and one on the other side of the hydraulic junction - which seems logical. However, it may have been the former, i.e., both washers together on the sensor side.
Do you remember?
Sat Apr 21, 2018 7:14 am
Piaggio MP3 500
Piaggio MP3 500
Sat Apr 21, 2018 7:14 am linkquote
One more detail: do you have to "exercise" the tilt-lock in the midst of pushing new fluid up into the reservoir to make sure bubbles are out of all parts of the hydraulics before or after you fully tighten the sensor?
Sat Apr 21, 2018 7:18 am
Sat Apr 21, 2018 7:18 am linkquote
Do you remember?
One washer on each side of the hydraulic hose.
Sat Apr 21, 2018 7:19 am
Sat Apr 21, 2018 7:19 am linkquote
Fully install the new sensor, then push bleed from the bottom to fill.
I did not exercise the tilt lock until after the system was full, and that was just to confirm function. If there is air in the system downstream of the pump, you'll get the horn....
Sat Apr 21, 2018 10:43 am
Piaggio MP3 500
Piaggio MP3 500
Sat Apr 21, 2018 10:43 am linkquote
Success!! I can't thank you enough for your help. Gave me the confidence to tackle this kind of job for the first time. I could see some fluid in the connector housing of the old switch - clearly that was at fault.
No beeps after the new switch was installed. Gave it a test ride turning the tilt-lock on/off several times. I'll park it on the stand with tilt-lock off from now on.
Thanks,
Rod
Sat Apr 21, 2018 10:57 am
Sat Apr 21, 2018 10:57 am linkquote
Thanks,
Rod
Bravo! Glad it worked out.
And yes, that brake fluid in the connector is a give-away, you found the problem.
Cheers!
⬆️    About 4 years elapsed between posts    ⬇️
Sat Aug 27, 2022 3:28 pm
2008 MP3 500
2008 MP3 500
Sat Aug 27, 2022 3:28 pm linkquote
Pro tip: don't overtorque it.....
Over tightened
Sun Aug 28, 2022 4:05 am
Sun Aug 28, 2022 4:05 am linkquote
Ouch.
Sorta surprised to see you got the front end out; good work there at least.
  DoubleGood Vespa Design
[ Time: 0.0417s ][ Queries: 7 (0.0185s) ][ Debug on ][ 211 ][ Thing One ]
