@chopper1966 avatar
Super 1966
@chopper1966 avatar
Super 1966
Hi Scooter geniuses,
Recently I replaced the headset bearing in my 1966 super. Now I have no lights! I checked the obvious stuff like making sure everything is plugged in and bulbs are good. I wouldn't know how to troubleshoot this. Does anyone have a suggestion or know someone in the Louisville area? Thanks!
I'm in Etown. Post a pic of the switch.
@chopper1966 avatar
Super 1966
@chopper1966 avatar
Super 1966
Hey Panchoboots thanks for the reply! I just moved here like a month ago. Is there a big scoot scene here? Thanks for your help!
@chopper1966 avatar
Super 1966
@chopper1966 avatar
Super 1966
2nd pic
I haven't seen a single vintage scoot but I haven't been here long. First thing I would check is if you pinched anything putting the head set on if the bulbs have been replaced. Second thing is get a wiring diagram and see if it matches what you got. If you have a volt meter, check stator out put
@chopper1966 avatar
Super 1966
@chopper1966 avatar
Super 1966
Stator should be fine, the engine runs.
Is there any help in Lousiville? Does anyone have a advice or could share a walkthrough?
@vma1racer avatar
@vma1racer avatar
So, that does not look like a non-battery light switch. No real non-battery post-1963 sprint/super/vnb/vbb has that bottom toggle switch.
Have you looked at the scooterhelp wiring diagrams? I understand wiring diagrams might be hard to interpret, especially if you have incorrect components installed.
@vintage_red_matthew avatar
MV Santa
MV Santa
Hey, Joel. I didn't see this thread until today. How's it been going at your new place? Did replacing the bearings finally fix your shuddering problem?
As for the headlight not working, hows this for obvious? Are you sure your bulb isn't burned out?
He has a P200E motor in it so it has a battery.
Edit: I'm not sure about the battery. He's not running blinkers so he might not have one.
@chopper1966 avatar
Super 1966
@chopper1966 avatar
Super 1966
Hey Matthew!
It's going great here. My internship is going very well. I already won an award for my research. Hows it going with you? Hows the lady?
Riding here is really great, the scenery is beautiful. I hope you can check it out sometime. The VLB is running well. It has not lost it's timing!
After taking the super apart I noticed the bearing was broken. I brought a kit and replaced everything. I haven't got to test it because I don't have any lights! I have several sets of bulbs. I did try new ones so I don't think it is that. I think I might have a short but I don't know how to troubleshoot electrical. Any tips?
Thanks for your help man.
@chopper1966 avatar
Super 1966
@chopper1966 avatar
Super 1966
Bump
@mjrally avatar
@mjrally avatar
1. Take your headlight out and make sure everything's clean, intact and secure. Take a picture and post it on here so we can see where the wires go.
2. Go to this website and try to find something that matches your existing wiring harness.
http://www.scooterhelp.com/electrics/60.elec.html
3. Open up the black plastic wiring junction box at the top of your motor. Take a pic of what wires connect to what and post it up here.
[ Time: 0.0127s ][ Queries: 4 (0.0045s) ][ live ][ 313 ][ ThingOne ]
