GTS250, VBB, Heinkel Tourist, Heinkel Cabin Scooter
Hi:
I'm considering using an MP3 or Vespa GTS drivetrain from a salvage vehicle to power a microcar. I have not been able to find an MP3 near me to take some measurements that would help me determine if the engine unit would fit.
Here are the measurements I need:
1. length of engine from front of cylinder to end of rear tire;
2. rear tire circumference
3. distance from front of engine to middle of engine pivot
4. engine at widest point - probably where the exhaust and CVT belt are..
If anyone could take measurements for me I would greatly appreciate it!
thanks
Shawn
@klaborde avatar
@klaborde avatar
Re: MP3 400 or 500 owners- could you measure something for m
shawnm wrote:
Hi:
thanks
Shawn
Some of what your asking is difficult unless you have the bike body parts removed to be accurate.
Keith,
Marietta, GA
Hi:
The measurement that is probably most important for me is the overall length of the unit. I have 36" to play with unless I want to do some metal fabrication. I have a feeling the MP3 powertrain is longer but I might swap out the back wheel. GTS 250/300 looks like it will fit though.
@klaborde avatar
@klaborde avatar
There are listed on ebay both a MP3/400 and MP3/500, so that maybe a good source. I have a Aprilla 250 Engine (Similar to GTS/GTV) sitting here on the floor, no Tire Mounted I could give you some information on.
Keith
Marietta, GA
Hi:
I'd love the measurements of the 250. If you measure from the front of the engine to the center of the rear hub for the length I can add in the wheel circumference myself.
thanks
Shawn
@klaborde avatar
@klaborde avatar
Here you go...
Just in case the text is too small...
Engine Width: 29"
Engine Pivot Point where Bolt Mounts: 8" from Front.
Engine's Widest Point: 16"
Aprilla 250cc Engine
This is great! thanks
Shawn
I will have a 500 engine in a couple weeks I am going to rebuild and can give you some measurements at that time.
Thanks I appreciate it
Shawn[/quote]
[ Time: 0.0113s ][ Queries: 4 (0.0023s) ][ live ][ 313 ][ ThingOne ]
