Any advice for removing the reflectors on a GTS? I bought the paint-matched plugs from ScooterWest but I don't want to jack anything up during removal. Tips or tricks?
@greasy125 avatar
@greasy125 avatar
reach in behind the panel with a pair of needle nose pliers and twist.
just get on the protruding stud and they'll bust right off
The quick and dirty approach is just break them off from the inside....they have a pretty flimsy plastic stalk with a metal clip. Seem to break off even if you're trying to remove the clip, so just have at it.
@wbdvt avatar
@wbdvt avatar
I have those ugly reflectors on my Sprint. What do you plug the hole with afterwards?
@boraxman avatar
GTS250
@boraxman avatar
GTS250
I used pop rivets to fill the holes...paint to match.
@paddlenround avatar
+1 - They bust off pretty easy.
In fact, the more difficult bit is putting them into the holes. You need to be careful not to apply too much pressure and risk scratching your paint or the tip of the nubs. I used a pair of pliers and a microfiber cloth. Gently squeezing until they popped in.
https://www.scooterwest.com/items/?_pageCCS=t#page=/item_details/Custom-Painted-Plug-Kit-For-Reflector-Removal/1635
These. Pick your color.
@abner_bjorn avatar
@abner_bjorn avatar
ACE Hardware sells black nylon plugs that snap right in for 25 cents each. $3.00 for a can of spray paint, and you're still money ahead.
ouch
yup and lowes carry some as well pretty home depot does too.
I personally just left mine black and not worry out color matchy matchy.
stickers are also a good option to cover stuff.
scooterless
scooterless
Fill and paint.
pro results with a spray can
GTS
GTS
You wouldn't be in the market for a bridge, would you?
[ Time: 0.0103s ][ Queries: 4 (0.0019s) ][ live ][ 313 ][ ThingOne ]
