@bdonley avatar
2009 Piaggio BV 250 Tourer
@bdonley avatar
Hi all-
Putting my GT200 back together. Having problems getting the glove box release linkage to work with the ignition switch. Any tricks to lining things up?
Thanks, Bill D
@dougl avatar
El Macho
KTM Super Duke 1290, Vespa GTS 300
El Macho
@dougl avatar
New ones have a few elastic bands hooked around the bottom toggle to the left of the fork tube... black toggle bottom left of your pic heading toward the sticker.
@bdonley avatar
@bdonley avatar
Ended up putting a bit of masking tape on it to hold it position. Worked great!
All buttoned up and going for a ride.....
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Good for you. I have used the masking tape technique before.
Glad you problem is solved.
GT200
GT200
Rubber band
Glad you didn't get in trouble by closing the glove box with it not engaged, like I did. that was a pain in the butt. Rubber band is the best mod for a glovebox release that is missing one.
@bdonley avatar
@bdonley avatar
I did have it not work. That's part of why I was doing it again. Also found a radiator hose that'd touched my PM header and needed replacement
[ Time: 0.0181s ][ Queries: 4 (0.0093s) ][ live ][ 313 ][ ThingOne ]
