![]() Sat Oct 28, 2017 7:48 am
MP3 500
Posts: 34 Location: Arkansas |
![]() Sat Oct 28, 2017 8:12 am
MP3 500
Posts: 265 Location: Columbus OH USA |
Re: fuzzy washer size
Once a Wing wrote: will a M22 washer work. 23mm inter d x 39mm od x 3mm thick. found it at fastenal.com |
![]() Sat Oct 28, 2017 9:07 am
Posts: 6941 Location: Madison, Wisconsin |
![]() MP3 500, GTS 250 (both 2008 MY), 2013 Piaggio BV 350, 2014 Can Am Spyder RT
![]() Sat Oct 28, 2017 12:17 pm
MP3 500
![]() RIP: MP3 500 - Brutto Moto
Posts: 5288 Location: Austin, TX |
Once a Wing wrote: was going to remove the 2mm washer and replace with a 3mm for a total of 3mm Otherwise PM me - the original Fuzzy Washer is a machined part - not stamped as is a regular washer. I have a very few left. |
![]() Sun Oct 29, 2017 9:10 am
MP3 500
Mon Oct 30, 2017 7:01 am
GTS 300ie & MP3 500 Sport
Posts: 23 Location: PH |
Mon Oct 30, 2017 7:30 am
kshansen wrote: Hate ask a dumb question here and I will say I only happened on this somewhat by mistake on ModernVespa. What is a fuzzy washer? I spent 40+ years working as a heavy equipment on all kinds of different machines and never came across that term. |
roy.santiago wrote: kshansen wrote: Hate ask a dumb question here and I will say I only happened on this somewhat by mistake on ModernVespa. What is a fuzzy washer? I spent 40+ years working as a heavy equipment on all kinds of different machines and never came across that term. |
![]() Mon Oct 30, 2017 3:50 pm
2008 MP3 400
Posts: 258 Location: Land of Oz |
kshansen wrote: OKAY! Now I think I know what washer is being talked about but not sure the reason for the terminology! |
FrogmanDave wrote: kshansen wrote: OKAY! Now I think I know what washer is being talked about but not sure the reason for the terminology! The few Fuzzy Washers I have remaining are from batch #3 which I paid for. I won't be ordering any more because they now have a minimum order amount and a setup fee. |
![]() LXV 150 3v ie. Midnight Blue (Sold) Now Honda Zoomer X
Posts: 3734 Location: Kingdom of Lanna |
BubbaJon wrote: Several of us were discussing a new French racing variator. BubbaJon wrote: Make sure the washer is centered if the inner diameter is larger. Hat off to Fuzzy for being inquisitive, and following his curiosity. Too many simply follow the crowd. |
BubbaJon wrote: FrogmanDave wrote: kshansen wrote: OKAY! Now I think I know what washer is being talked about but not sure the reason for the terminology! The few Fuzzy Washers I have remaining are from batch #3 which I paid for. I won't be ordering any more because they now have a minimum order amount and a setup fee. |
BubbaJon wrote: Not entirely accurate. Several of us were discussing a new French racing variator. Analysis revealed a different profile but also that it was wider apart by 1mm. So this started speculation on whether if you doubled the original washer if it would do the same thing. Fuzzy volunteered to find out on his 400. It did work to a point but also brought a few other issues like belt rubbing and such. We opined the French engineers must have settled on that 1mm extra for good reason. I had a buddy in a machine shop so we all chipped in and had the first batch of Fuzzy Washers machined. They were named after Fuzzy because he had the balls to risk his scooter for science. The few Fuzzy Washers I have remaining are from batch #3 which I paid for. I won't be ordering any more because they now have a minimum order amount and a setup fee. Please reach out to me through PM if it works for you. Thnx,BW |
