I've got a request! Any folks out there who ride an early 1960s VBB (150cc, 4-speed) which has a straight, undamaged frame and fork-slash-front end?
I'm looking for the length of the distance measured from the frame just below the front seat (above the choke knob and fuel tap rod) directly forward to the ring on the steering column... as pictured below. i'd be grateful for your input!
I just got a '64 VBB that's in overall fair to good condition, except that the front fork lower portion and front wheel are bent backward toward the rear -- most likely from a past collision or other type of impact. That's got to be fixed or replaced obviously. But my other concern is whether the frame or leg shield may have also been affected. Thanks to those in an earlier thread for their suggestion to double-check this.
Cheers!
