@shipscat avatar
vespa 125 vnb1t
@shipscat avatar
vespa 125 vnb1t
hi peeps
i need some help with the flasher relay wiring
the scoot has a 12v conversion , new wiring loom from sip , 3 pin regulator
but the loom only has one feed wire for the relay , but the relay is marked 3 wires red white and green
does anyone know which pin does what on the relay
thanks in advance
@ginch avatar
@ginch avatar
Pretty sure one terminal is for the warning light, so you can probably ignore that one... centre terminal perhaps?
[ Time: 0.0073s ][ Queries: 3 (0.0014s) ][ live ][ 335 ][ ThingOne ]
