@harbinger avatar
@harbinger avatar
Hello fellow MVers.
I have recently put Bitubo shocks on front and rear. They are set to factory defaults and while I do feel more planted at speed I can tell they need a bit of tweaking.
So my question is, how can you tell when the shocks feel "just right"?
Maybe a stupid question but I'm not afraid to ask those on occasion.
Should the scoot feel nice and smooth or is it better to have them a little stiffer and feel the bumps? I've always run my scoots with stock shocks and have never adjusted them. I will adjust my tire pressure for 2 up and heavy loads etc but have left the shocks alone.
Any advice is most welcome. Apologies if this has been covered ad nauseum so I someone wants to point me to a thread, that's cool as well.
@turboblew avatar
"MY WIFES" 2010 GTS FASTER & BETTER ENGINEERED THAN YOURS!!
@turboblew avatar
Really the only way to tell is get a notebook and write down your settings and your ride impressions feel. Also the weight.
Maybe start with 0 preload on the springs then turn your rebound /compression settings to 1 extreme or another.
There will never be an ideal setup unless you ride the same roads.
@mike_holland avatar
GTS300 Super 2023 Beige
As Turboblew says, they will never be perfect for all roads and conditions. Mine feel perfect when I am at speed down the highway, but on one stretch of bumpy road just near my home I always feel they are set too hard.
Mike
@orltee avatar
2017 GTV 300
@orltee avatar
2017 GTV 300
I had the dealer install new front & rear shocks several months ago and found they were too stiff for me based on the dealers adjustment.
I found the instructions in the link below and slowly adjusted the shocks for more comfortable ride. Adjusted a little then went for a ride until I got the front dialed in to where I feel comfortable with compression spring about 50% and rebound value set to 4 clicks.
Bitubo's on my LX, anyone know the best adjustment?
[ Time: 0.0120s ][ Queries: 4 (0.0039s) ][ live ][ 335 ][ ThingOne ]
