Hi all. I'm pretty new to the the forum and would love some advice. I recently purchased a 05 Stella 150 that had some high mileage and I'm completely going through it and decided to kit it out a bit. I've got a 166, race crank, 26/26, expansion pipe, and all new bearings, reinforced clutch, etc. etc.
I've matched the cases to the 166, matched the new carb through the reed area (cutting out the bar), and now I'm cleaning up the ports on the cylinder. Everything is going well. I'm planning on polishing the exhaust port to a nice finish.
My question: how polished should the surfaces be on the cases and intake side? I've read a lot on the web and get mixed options. They are currently very smooth, almost polished, but then I hit them by hand with 80 grit to leave small scratches in the surface (as I read on some forum). Is it worth it to find a small bead blaster and put back that sand blasted finish?
Thanks in advance!
