@acox6252 avatar
2007 LX 150
@acox6252 avatar
2007 LX 150
Hope some of you out there can offer some opinions or suggestions. Sometimes my 2007 LX 150 will crank right up. Sometimes you turn the key and the diagnostic code light says that the transponder is missing or defective. When this happens I have to go to the CDI and disconnect the transponder antenna connector and then reconnect it and it will work fine again for a while. Since the CDI unit plug is not the most accessible thing on a Vespa and the problem always happens at the worst times, I have searched for the problem. I have replaced the antenna and connector (even though the old one checked ok), I have cleaned and aligned the connector pins, I have applied dielectric grease. STILL HAPPENS! I having to leave the CDI hanging out the front access plate hole to insure I can get back home. Any help out there??????
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
Below is the normal sequence: (from our Wiki)
A normal fully working machine should do the following LED sequence:
SERVICE Key ON, One short 0.7sec flash then LED OFF... Machine will start and run.
Or if you use the master key:
Master Key ON, One short 0.7sec flash, then a number of short 0.5sec flashes then LED OFF - machine will start and run. (the number of short 0.5sec flashes depends on the number of keys you have coded to the system, upto a maximum of 7; so 2 flashes means 2 working keys, and so on).
What are you getting?
@acox6252 avatar
2007 LX 150
@acox6252 avatar
2007 LX 150
Crank or not to crank
NightWing, thanks for reply, if the connection is good I get the exact sequence you listed. If the connection fails I get, the long flash and then three .o5 sec. flashes then diagnostic light goes out telling me the engine is not ready to crank. On one occasion I was riding and the engine just cut off. But so far every time I get the fail code unplugging and then re-plugging the antenna connector has temporarily cured the problem??????
@nightwing avatar
Contributor
Contributor
@nightwing avatar
I can't find anything in the list that indicates a long flash. The red light needs to be off before it will start.
Here is the complete list from our wiki:"
Immobilizer LED codes
The immobilizer function is indicated by the Code LED on the dash display. The ECU has to obtain authority from the aerial, which is circular and surrounds the ignition lock behind the glovebox panel (active antenna).
Keys should not be on a metal key ring or with other keys. Sometimes this can upset the system.
To Diagnose the system, turn the ignition on with a Normal key (not the master key) and note the LED on the dash.
Listed below are what options the LED will show. Find out what yours does, get the reference letter (i.e. yours is doing as described in C... then go further down for more details on the fault and cure)
A= Single 2sec flash, then LED stays OFF.
B= Single 2sec flash, then 2 quick 0.5sec flashes, then LED stays ON.
C= Single 0.7sec flash, then 1 quick 0.5sec flash, then LED stays ON.
D= Single 0.7sec flash, then 2 quick 0.5sec flashes, then LED stays ON.
E= Single 0.7sec flash, then 3 quick 0.5sec flashes, then LED stays ON.
Further details on the codes above...
A= ECU is not programmed.
The LED gives a single two second flash. The Engine management light will be on.
You should get this code when you have fitted a new ECU.
The immobiliser system is working correctly and only needs programming.
B= ECU is not programmed. Transponder is not detected.
The LED gives a single two second flash, then two short flashes, then comes back on..
The ECU is not programmed (as above) but also the chip in the key has not been detected.
You must resolve the transponder problem before trying to program the ECU.
The master key will give this fault if the chip is hinged out.
If you have another key try that, if it is still not detected it is probably the aerial.
Verify that the aerial is correctly located and secure in it's mounting around the ignition lock.
C= Break in the Serial line.
A single short flash, pause, then a second short flash, LED then comes back on.
There is a break in the wire between the ECU and the aerial (active antenna).
The Orange / White wire on pin 7. is the link.
D= Transponder is not detected.
A single short flash, then two short flashes, then comes back on.
The chip in the key has not been seen.
Either there is a fault with the key or the aerial.
E= Transponder is not recognised.
A single short flash, then three short flashes, then comes back on.
The chip in the key is seen be is not recognized.
The key is not programmed into the immobiliser memory.
You are using the wrong key or it needs to be programmed into the immobiliser memory.
Only when the LED remains OFF should the engine start.
Dealers can use the Digitec or Axone tester to read fault codes from the ECU about the problem, but it doesn't tell us much more than the above info, although you can see how many keys there are coded to the ECU, etc.
If you have a immobilizer fault that just suddenly appears, and its LED flashing code works out to be A in the above table, then before you try anything else, check the HT lead and plug cap, It is possible that extreme electrical interference from a faulty HT circuit could upset the immobiliser. Plug cap must be at least 5000Ω. Change the cap and lead if suspect. A resistor spark plug must be used. Then try re-programming the immobiliser. If it will not re-program then it is faulty.
@acox6252 avatar
2007 LX 150
@acox6252 avatar
2007 LX 150
Sorry NightWing, I was not clear or correct in my description. I know it is hard to help someone who gets their symptoms wrong but we make mistakes, again sorry and I really do appreciate the help. The long flash I referred to is the .07 sec flash, the short flashes are the .05 sec flashes not much difference at all. going to the source of this problem tells me that I told you wrong, when I have a connection the light does stay on and the engine cranks. When the fault or lack of connection occurs it is "E" that you listed below. Sorry I did not have it together.
To be totally clear, when fault happens it can be with master key or blue key. .07 flash, 3, .05 sec. flashes and then light is off, all running lights on, engine will not crack.
When fault does NOT happen with blue key, all running lights are on and diagnostic light is solid light and engine cranks. only difference with master key is slave key count in flashes.
This time all is correct.
@nightwing avatar
Contributor
Contributor
@nightwing avatar
The LED should go out before starting.
@acox6252 avatar
2007 LX 150
@acox6252 avatar
2007 LX 150
I know, but if the connection is bad on the try, it only repeatedly blinks. When it does go out...it will crank just fine. Very strange. Much easier to deal with a problem that constantly happens. Maybe some one who has had this problem will read it, I'm at a total loss.
@berto avatar
@berto avatar
I have had this problem occasionally (maybe 1 every 20 or 30 starts, and more often when it's really cold outside).
Fortunately, I have not had to do anything unusual to clear it. If I notice the immobilizer light does not clear, I just turn the key off and back on, and that has always done the trick so far.
@acox6252 avatar
2007 LX 150
@acox6252 avatar
2007 LX 150
Berto, sounds like the same problem only key off and back on restores your connection. with me it requires disconnecting and re-connecting the immobilizer antenna at the CDI. Wish I could cure it at the ignition key.
GT 2.4
GT 2.4
We are working on a permanent solution to all the immobilizer problems and the issue with special keys for carburetor bikes. It should cost about what a new set of immobilizer keys and tumblers currently costs at your favorite internet retailer, unless that's us. If that's the case, it's going to be a bit more, but it's a permanent fix for just about every immobilizer and key problem you can imagine. We are about a month out from knowing if we have the solution or not. If you can do it, hang on. I'm getting some samples of whatever it is that's supposed to fix this in about a week or ten days, and this sounds like an ideal test situation.
@acox6252 avatar
2007 LX 150
@acox6252 avatar
2007 LX 150
Crank.or not to crank
Motorists, that sounds wonderful. Do you need contact information for me?
@acox6252 avatar
2007 LX 150
@acox6252 avatar
2007 LX 150
To crank or not to crank
Sorry, should say "Moto Vista" hate auto correct.
[ Time: 0.0258s ][ Queries: 3 (0.0066s) ][ Debug on ][ 313 ][ Thing One ]
