Think I have an air leak.
I recently installed a DR 85 kit on my 50s. It seemed to be running OK at first, but now sounds like I have an air leak.
Symptoms are that after riding a mile or so, it wont rev down with throttle off, and I've had to use the kill switch to drop the revs down.
Now that the carb is clean, it starts first kick and idles well.
Yesterday, I dropped the motor again and basically checked every bolt I had touched during the install. A couple needed a tweak but generally it all seemed OK.
Couple of thoughts.
1. I used the supplied base gasket smeared in oil as per the instructions, [ original barrel had no paper gasket ] but in hindsight I may not have cleaned off the previous gasket sealer as well as I could have. I don't recall there being much of it left, but the surface wasn't dead smooth.
2. I noticed yesterday the inlet bushing was barely through the frame enough to get the clamp completely on to it. Almost as if the engine was sitting too low. I hadn't noticed that previously but may be something.
3. I had not removed a barrel before, so I am wondering how you torque the barrel nuts down when you need an open ended spanner and can't use a torque wrench. They seemed pretty tight but.....[ the 50s does not have studs that go through barrel and head, but separate barrel nuts and head bolts ]
