motresyklman wrote:
I did a search of the forum for DrPully & Fuzzy washers. Found plenty of info...but most is from 2014. Before I start contacting listed sources for belts, fuzzy washers Dr. Pully , Variator tool etc., has anyone done all that recently? New sources? Old sources no longer in business? Just trying to avoid reinventing the wheel.
Thanks much,
Motresyklman
scooterpartsco.com for a belt get the malosi it is much cheaper than oem and as good or better. ( all I use now)
than can also get you dr pulley sliders or get you stock weight rollers.
I have had the same set of 17gram sliders in for 30,000 miles and they look great with now wear.
I am sure they also can get you the buzzetti variator tool.
Fuzzy washer might have on laying around send me a pm with your address.
