New tires installed at dealer. Appears they sre 5 years old before mounting. Still okay to use?
Posts: 12792 Location: Fond du Lac, Wisconsin |
The numbers are 1012, so the tenth week of 2012. So does the life of the tire start now or in 2012.?
Wow. Kind of old for installing as new. I'd say you're okay if you get mileage on quickly. OTOH, if you're likely going to put on less than 1K miles in a year I'd be a bit more concerned. Unless they're stored hermetically sealed or something, they'll still age, probably better than on the street.
That is New Old Stock... not bad if you're restoring a vintage scoot or car, but not so good for everyday tires. Tenth week of 2012 is 6 years ago.
Make sure you're reading the right number on the tires. And ask the service manager about it.
"MY WIFES" 2010 GTS FASTER & BETTER ENGINEERED THAN YOURS!!
Posts: 488 Location: STAYOFFVILLE |
I mean if I was buying new tires... I want them produced in the same year I was buying them. Even at significant discount.
That being said... I had mounted up a set of 10 year old, never used race tires on my track bike. They worked fine at an elevated pace. You could ask the shop if they have a durometer... Where are you in North FL? |
Posts: 23305 Location: Harriman, Tennessee, Tn |
I personally would not be a happy camper over a dealer installing 6 year old tires. If I paid current rates for tires I expect them to be no more than 2 years old.
Anything older than that they would have to start dropping the price. tires are considered old after 5 years from manufacture date and should be replaced on age alone not mileage. |
Posts: 2038 Location: North Jersey |
5 year old tires are not considered old. That's old info. Tires made now are OK to use eight to ten years from manufacture. That info is from the tire manufacturers. Of course, in use, you still have to inspect them regularly for cracks, damage, etc.
And tires stored in a warehouse or dealership back room are not out in weather or UV rays like tires mounted on the scooter would be. If it were me, I'd pitch a bitch unless I expect I'd be changing them in 3 years anyway. |
Posts: 5102 Location: Australa, Mate |
I work at a tyre shop, & agree 5yr is about time to change them... Today I found the ones on my 6x4 trailer were from 2012 & 2009, oops!
Posts: 4723 Location: Twin Cities, Minnesota |
SubEtherBASS wrote: I work at a tyre shop, & agree 5yr is about time to change them... Today I found the ones on my 6x4 trailer were from 2012 & 2009, oops! |
SubEtherBASS wrote: I work at a tyre shop, & agree 5yr is about time to change them... Today I found the ones on my 6x4 trailer were from 2012 & 2009, oops! What are you basing this 5 year theory on? |
Posts: 8956 Location: Ashburn, Va. Home to the Internet |
turboblew wrote: SubEtherBASS wrote: I work at a tyre shop, & agree 5yr is about time to change them... Today I found the ones on my 6x4 trailer were from 2012 & 2009, oops! What are you basing this 5 year theory on? After the Firestone debacle this was stressed more by the tire and rubber manufactures. |
I change ALOT of tires and I am now changing my cost structure based on year of the tires. Example I just did a customers VTX 1300 that had original 2005 factory installed tires, they were hard as granite, so hard on the front I had to cut the bead once I got it to break off the rim. Which took me all my weight bearing down on the bread breaker on my NOMAR and still had to use a large vise grip C clamp to assist in getting the bead off the rim.
Once the tire was off it left pieces of rubber on the rim seat and 10 minutes of cleaning the rim to remove that, other wise when installing a new tire it would leak. I charged him triple what I normally charge because fighting with those ate a lot of time. My new fee sched will be by the date of manufacture of the tire. 5 years or less standard 5-8 years add 40% 9-12 years add 90% 12 years and up add 150% the longer they are on the rim before changing the harder they are. and they keep getting harder. ⚠️ Last edited by old as dirt on UTC; edited 1 time
Again, the tires were old but never installed til now. Stored in a warehouse out of the sun and heat. Does that increase the time to when installed or when mfg.?
zigzagguzzi wrote: Again, the tires were old but never installed til now. Stored in a warehouse out of the sun and heat. Does that increase the time to when installed or when mfg.? install and put any tire you want on, its your scooter. if your happy with it , its your scooter I install tires for folks and my standards are higher than most because its THIER scooter. |
So you are saying the life of a tire starts at the mfg date? Get it. So michelin now says six years with regular inspections after that. All is cool. As an aside, the last two mc i crashed were moto guzzis. Love em.
WEB-Tech wrote: Till just resently, EVERY tire and rubber manufacture recommended 5-6 year max. Tire compounds have been reformulated to hold up better against UV damage in the past few years. But a 6 year old tire may not have the latest compounds that are more UV resistant like the newest tires do. After the Firestone debacle this was stressed more by the tire and rubber manufactures. What firestone debacle? From the 1990s?? |
old as dirt wrote: I charged him triple what I normally charge because fighting with those ate a lot of time. My new fee sched will be by the date of manufacture of the tire. 5 years or less standard 5-8 years add 40% 9-12 years add 90% 12 years and up add 150% the longer they are on the rim before changing the harder they are. and they keep getting harder. Are their hard tires? Sure... you should charge whatever you want. I wont do Goldwing riders, Harley riders, or junk scooter owners stuff. Because... those are exactly the type of owners that would roll on 12 yr old tires...lol. Plus they NEVER can pull their own wheels. |
zigzagguzzi wrote: Again, the tires were old but never installed til now. Stored in a warehouse out of the sun and heat. Does that increase the time to when installed or when mfg.? The Firestone debacle was mostly caused by putting a passenger SUV body on a pickup truck frame and suspension which caused a hard ride. The "solution" to that issue was to tell the owners to inflate the tires to a PSI that was at least 6 pounds less than they knew the tires should have been. Most crashes occurred in the summertime Texas heat. Under inflation is very bad in the heat. |
zigzagguzzi wrote: Again, the tires were old but never installed til now. Stored in a warehouse out of the sun and heat. Does that increase the time to when installed or when mfg.? |
turboblew wrote: WEB-Tech wrote: Till just resently, EVERY tire and rubber manufacture recommended 5-6 year max. Tire compounds have been reformulated to hold up better against UV damage in the past few years. But a 6 year old tire may not have the latest compounds that are more UV resistant like the newest tires do. After the Firestone debacle this was stressed more by the tire and rubber manufactures. What firestone debacle? From the 1990s?? Read up on tires, that's how I learned and didn go to forums. Read industry news and manufactures websites. Learned a lot form rubber manufactures websites too. And put that tire crap on a motorcycle tire and take a hard turn and see what the hell happens. |
turboblew wrote: WEB-Tech wrote: Till just resently, EVERY tire and rubber manufacture recommended 5-6 year max. Tire compounds have been reformulated to hold up better against UV damage in the past few years. But a 6 year old tire may not have the latest compounds that are more UV resistant like the newest tires do. After the Firestone debacle this was stressed more by the tire and rubber manufactures. What firestone debacle? From the 1990s?? You'll laugh and make jokes till you have a front blow out at 70 MPH on the front. |
WEB-Tech wrote: And how do you keep that on the tread. Read up on tires, that's how I learned and didn go to forums. Read industry news and manufactures websites. Learned a lot form rubber manufactures websites too. And put that tire crap on a motorcycle tire and take a hard turn and see what the hell happens. Are you going tell me about taking hard turns next? Im pretty sure I know alil bit about that discipline! But always willing to learn more! |
[quote="turboblew"]
SubEtherBASS wrote: I work at a try shop. What are you basing this 5 year theory on? |
2010 GTS 300ie Super
Posts: 56 Location: Southport, NC |
Okay... so the front tires on my scoot are from 2005 and 2007 (original tires). About 3k on each scoot. I guess I should change them?
Posts: 3807 Location: Minneapolis USA |
RIP
Age of Tires
This Modern Vespa Forum gave me the coding to understand the
age of tires. My local Vespa Dealer put new tires on my 300 that were manufactured the year I bought them. Take my word, I am not a tech guy. Some of you know more than I do. I believe the age of the tire is important. I would be concerned about purchasing old inventory. Those tires are older than my Vespa. Bob Copeland |
I would never accept tyres that were over 6 years old. No way! Take 'em back and demand NEW tyres.!
6 year old tyres are NOT new tyres. They WILL have deteriorated and the rubber WILL have hardened. |
Posts: 7702 Location: Madison, Wisconsin |
I had a set of tires installed on my Focus at Walmart.
The tires were on super-sale, or whatever you want to call it when they're closing out a model. Got home to discover that not only were they old, they were rather dirty, having been stored apparently at the back of the trough. Anyway, when installed they were ~4-6 years old (like, as in, not only old and dirty, but ranging in age by a couple of years). Clearly they were scraping the bottom of the stock barrel. Sooooo, was I concerned? Nope. Focus has 4 tires, ABS, and traction control. And I drive it ~25,000 miles a year or more, so even if the tires last 100,000 miles I'll replace them by the time they turn 10 (age at which the manufacturer recommends changing out due to time). That is, if the Focus makes it to 300,000 miles (!?). Would I have accepted this on a scooter? Nope. But then, I'm not QUITE as cheep when dealing with scooter parts. |
Madison Sully wrote: I had a set of tires installed on my Focus at Walmart. The tires were on super-sale, or whatever you want to call it when they're closing out a model. Got home to discover that not only were they old, they were rather dirty, having been stored apparently at the back of the trough. Anyway, when installed they were ~4-6 years old (like, as in, not only old and dirty, but ranging in age by a couple of years). Clearly they were scraping the bottom of the stock barrel. Sooooo, was I concerned? Nope. Focus has 4 tires, ABS, and traction control. And I drive it ~25,000 miles a year or more, so even if the tires last 100,000 miles I'll replace them by the time they turn 10 (age at which the manufacturer recommends changing out due to time). That is, if the Focus makes it to 300,000 miles (!?). Would I have accepted this on a scooter? Nope. But then, I'm not QUITE as cheep when dealing with scooter parts. |
I be asking for new tyres if that's what you paid for not old tyres
seems to me they give you old stock tyres |
old as dirt wrote: Madison Sully wrote: I had a set of tires installed on my Focus at Walmart. The tires were on super-sale, or whatever you want to call it when they're closing out a model. Got home to discover that not only were they old, they were rather dirty, having been stored apparently at the back of the trough. Anyway, when installed they were ~4-6 years old (like, as in, not only old and dirty, but ranging in age by a couple of years). Clearly they were scraping the bottom of the stock barrel. Sooooo, was I concerned? Nope. Focus has 4 tires, ABS, and traction control. And I drive it ~25,000 miles a year or more, so even if the tires last 100,000 miles I'll replace them by the time they turn 10 (age at which the manufacturer recommends changing out due to time). That is, if the Focus makes it to 300,000 miles (!?). Would I have accepted this on a scooter? Nope. But then, I'm not QUITE as cheep when dealing with scooter parts. |
old as dirt wrote: can't compare car tires with m/c tires. cars have 4 points of contact, m/c's 2 very small points of contact. blow out a tire on a car meh no big deal really, blow out a tire on a m/c REALLY BIG DEAL. Changed the setup to a hybrid tubeless. |
