Killo wrote:
The Allstates are pretty much like the VNA/VNB Vespas. There should be a circlip on top of the flywheel nut. As you remove the nut, it will pop the flywheel off of the tapered shaft.
If the flywheel has been on there a long time good and tight, it might not pop off so easy. Sometimes it's on so tight that the circlip pops out instead of the flywheel. I've had good luck with stubborn ones doing this:
First remove the circlip and nut/washer then a little penetrant on the shaft.
Now clean the groove and stretch the circlip a bit so it's tight in the groove with the sharp edge OUT & nut back in place.
Some gentle heat with a hot air gun on the FW hub can help.
Use an offset box end wrench on the nut and if the circlip starts to deform, I leave it under load and use a centerpunch & small steel hammer to give a sharp tap in the centerdrilled hole at the end of the shaft as I slowly tighten the wrench which usually pops the FW loose.
