bluecloud I have the typhoon manual (which looks like the same steps as the vespa manual). The steps show the job getting done from inside the crankcase. The video from
MJRally show access from the other side. I assume the book is correct, but it doesn't say if the wheel/brakes need to be removed. Do they?[quote}
The book is correct. I mentioned above that if it wasnt behind the tire, itd be inside. I dont know all the particulars of the Typhoon.
Also, it sounds like a lot of special tools are needed. Kind of makes me feel like I should get the local vespa service shop to do this job for me.
Can this be done without special tools?
If you already can remove the clutch, it should just be as simple as removing the gear cover from the inside via the 5 screws. Replacing the shaft and gasket, buttoning everything up and then re-torquing the clutch again.
waspmike I might be interested in upgrading to 80cc however isn't this scooter restricted some other way? And if I get this done at the service shop, I assume they wouldn't do the install.
All the restricted 50cc scooters that ive seen had a washer in the variator, smaller main jet and exhaust cone. Have you dealt with all those?
