GT125l
GT125l
My front right indicator is not working at all I have checked the bulbs they work perfect. The rear one is illuminating perfect but it's not flashing quickly like if i unpulg the left one .the left indicator is working perfect. Do you think that could be a wiring issue somewhere as i have tried the left one in the roght and still doesnt work or do you think it could be the indicator rely? I am a bit confused
I think there's a fuse that's out. My mechanic does my work so i can't remember where it is. Nerd emoticon I wanna say up front somewhere,
carnaby 125
carnaby 125
It's not a fuse if fuse was blown none of the indicators would work
I had this issue last month but only one indicator wouldn't flash and turned out the connection block for all wires was some corrosion
You need to take off the front panel and follow the indicator wires and it should lead you to a connector block and see if there's any connection snapped inside or badly rusted
@bald_wasp avatar
@bald_wasp avatar
I've had this problem a number of times. In almost every case it was traced back to a wire that had snapped off of an aftermarket modulator kit. Most likely a wire issue.
w.
[ Time: 0.0083s ][ Queries: 3 (0.0017s) ][ live ][ 339 ][ ThingOne ]
