2022 Honda PCX 150A, 2018 GTS300 [sold] & 2015 GTS300 Super [sold]
My ABS rear tone wheel took a beating when I removed my rear tire, and it's bent. I know absolutely nothing about the technical aspects of ABS. Does the tone wheel need to be in good shape for the ABS to work? If I order a new tone wheel for installation, can I still ride and just not enjoy the benefits of ABS while I'm waiting for the part to arrive?
@mingo avatar
GTS310 SuperSport
@mingo avatar
GTS310 SuperSport
Without it, you won't have ABS or ASR, but you can ride. The ABS light will stay on. If the speedometer stops working too, then you'll know it's also running off the ABS ring.
Let us know the results.
@waspmike avatar
@waspmike avatar
There is a thread with instructions for setting up the ABS/ASR after tire replacement. https://modernvespa.com/forum/topic159148?highlight=asr
I think there is reference to tolerances or set up distance between the abs wheel and sensor. If you can straighten out the wheel and get the distances correct/within tolerance will be OK.
[ Time: 0.0074s ][ Queries: 3 (0.0015s) ][ live ][ 343 ][ ThingOne ]
