@quattrovalvole avatar
09 GTS300 Super black, 04 GT 200 smoky, 05 GT 125 smoky (in pieces)
When I stop at a light for a little while the idle will develop an erratic miss, like it skips or something.
At first I thought the spark plug might be failing prematurely, so I replaced it but the problem persists.
What else can I check? Thanks.
@prcrstn8 avatar
2006 GT
@prcrstn8 avatar
2006 GT
Replace the carburetor with fuel injection?
Seriously, mine does that too - it's a single-cylinder carbureted engine, there's nothing you can do about it.
A guy on an old Triumph was stopped at a light today. I admired his bike as I walked by and just at that moment it died. It took him 3 or 4 kicks to get it started again. Look on the bright side - modern engines, even carbureted ones, are much more refined and reliable than they used to be - as long as it's not stalling out when you're at a light it's ok.
Vespa GT 200
Vespa GT 200
Re: GT getting an erratic miss during idle?
Hi,
Check the needle valve and the carburettor float for proper height. I suspect that is where your issue lies. Good Luck!...
Happy Motoring!... Jim
Thanks for the response, now I need to figure out how to adjust these items on the carburettor.
[ Time: 0.0112s ][ Queries: 3 (0.0036s) ][ live ][ 318 ][ ThingOne ]
