Where can I get the water pump screws (M5x21mm/part #015856) in socket hex form (I am not sure of the threading type they use)?
The size of the hose used to bleed the air?
A thick grease to hold the O-Ring?
The screw to open the compartment where you put the coolant is totally loose in my scooter (no matter how much you screw it), it feels like the housing of the screw has detached from the body or something. What can be done?
