It usually takes 1-3 times with auto start before et4 starts? Starter relay? Spark plug? Ignition coil?
Or is 1-3 times totally normal?
Anyone?
are you holding the starter button down until the motor catches or pushing it and then letting off?
How long can I hold it down for? I was under the impression only for 1-3 seconds
Pump the gas a couple of times so the accelerator pump primes the carb, then hold the button down until the motor catches, just like you would your car or anything else with a motor. You are not helping your bike at all by poking at it for a few seconds then letting up. That seems to be the new thing, and someone's going to come along and say why it's better than doing it the right way, and when I hear it in the shop, it gets on my nerves. Carb bikes are never the same, and you might find that you need to give it about a quarter throttle while you start it to get it to fire off. If you've ever been on a carb bike that just fires right up as soon as you touch the starter button, don't let that make you assume they all are going to do that or need to be fixed if they don't.
Have you ever changed the fuel and vacuum lines? Try that. They should be done anyway. Mine last 4yrs tops. Stranded me in a parking garage and ever since then i've been diligent in replacing them.
@franknbrew avatar
2006 LX 50
@franknbrew avatar
2006 LX 50
That's exactly how I start both of my 50cc scooters. Twist the throttle twice, open the throttle about 1/5, hit the start button and they fire right up. After 2 seconds I let go of the throttle, raise the stand, twist and go.
[ Time: 0.0113s ][ Queries: 3 (0.0029s) ][ live ][ 339 ][ ThingOne ]
