I rebuilt my front brake caliper: new pads, new pin with the little snap clip, new clip that sits on top of the pin. https://www.scooterwest.com/vespa-caliper-hardware-kit-498849.html
I changed my front rotor: Removed the cotter pin, cap, circlip, nut. Then I took some suggestions online to remove the hub by hitting the old rotor attached to the hub with a rubber mallet-nothing happened. So I bought a 3 arm jaw gear puller, which worked like a charm and removed the hub with the old rotor attached.
NOW:
I attached a new rotor to the hub, put the hub on with the rotor, attached the circlip, nut with a torque wrench, cap, cotter pin. Then I attached the caliper to its rightful place on the rotor. When I put on the front wheel, the pin from my caliper was digging into my wheel so much that the wheel doesnt even turn.
My question is, has anyone heard of this type of thing? Is my hub crooked now? Do I need to change my ball bearings for some reason? Is that pin too long? (I threw out the old one, d'oh). Trying to figure out where to start here before I start buring more $...
