Hi, recently got my PX 125 serviced and got an expert to look at and set up my carb. Have to say it goes like a dream now and plug is showing a good colour.
Today though, (bearing in mind the weather is rather warm) I turned the engine off after a ride for about 5 mins. When I started engine I revved it up it almost died 1/4 throttle but I managed to 'rescue' it by turning the throttle further. It would normally do this with a cold engine. After less than a minute of riding the problem cleared so I don't believe the carb is set too lean on the idle. I'm reluctant to adjust anything as the bike goes beautifully otherwise having been adjusted by a renowned and trusted scooter mechanic.
A similar thing happened when I forgot to turn the fuel tap on and the bike cut out. Once I had turned the tap on I was getting the above problem for a few mins. Any thoughts?
