Piaggio MP3 500
Piaggio MP3 500
Howdy,
I need the part number or the bearing size (ID,OD,width) for the ball bearing that sits behind the rubber buffer on the swing arm at the front of the engine. One side is rattly and needs replacing- and I can't find it anywhere on the parts diagrams on AF1. In fact, in the drawings, I can't even see the loop in the crankcase casting where the bearing is installed. And it doesn't show on the swing arm diagram. Has anyone replaced one of these things? It looks like a press fit into the crankcase casting.
Thanks for your help-
@web-tech avatar
@web-tech avatar
The bearing should have a Timken number on it. If it does have a number, take it to an auto parts store and they can order one for you.
Not an AutoZone. A real parts store like NAPA, Car Quest or a local auto parts store.
@klaborde avatar
@klaborde avatar
I see the OP asked similar...
I am pretty sure scooterpartsco.com has them on their website.
The last time I looked they listed OEM, and US Parts.
I am curious, how do you knock that out?
Do you use a socket as a press, and knock it out?
I am considering power coating my swing arm in black.
I was thinking about removing the bearing, and then install a new one after the powder coat.
Keith,
Marietta, GA
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
HK1514
Piaggio MP3 500
Piaggio MP3 500
Thanks, Maksor!
To remove it, I'm planning on heating the outer crankcase loop with a heat gun and tap it out with a socket extension through the bearing on the other side. If it doesn't come out easily, I'll heat it with a torch. I'll post a pic or two if I get to it tonight.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
Crankcase isn't the swingarm
the crankcase bearing is 6003RS a ballbearing and those you can tap out with a hammer agains the bushings inner side
the 1514 is a needlebearing the ballbearing last longer then the needlebearing in the swingarm
2 and 10 are 1514
Piaggio MP3 500
Piaggio MP3 500
OK, that sounds more like the one I want- 6003rs, 17x35x10. The other pin bushings in the swingarm itself seem to be OK on my bike. Thanks Maksor! I knew you had the information I needed!
@klaborde avatar
@klaborde avatar
Squeazel wrote:
Thanks, Maksor!
Thanks on Picture...
Keith,
Marietta, GA
Piaggio MP3 500
Piaggio MP3 500
Maksor is right, to remove, just tap it out with a socket on an extension. But the bearing number is 6004RS, 20x42x12 sealed ball bearing rather than 6003RS.
Here's a pic. I don't think you need to remove the engine to replace it- just the bolt and the rubber buffers, let the swing arm frame member drop down, remove the spacers and drive out the bearings. I didn't need any heat, but I'm going to put the new bearings into the freezer for installation; then they'll just slip right in without pounding.
[ Time: 0.0170s ][ Queries: 4 (0.0023s) ][ live ][ 343 ][ ThingOne ]
