I apologize in advance for the lengthy post that follows.
I have a Derbi Boulevard 150 a Vespa LX150. Both have the same Piaggio engine.
I recently noticed that the Derbi battery was not charging as quickly as the Vespa battery when both were put on the battery tender. A test of the voltage at the battery terminals while the bikes were running indicated that the Derbi was not charging the battery, reading 12.4 volts (essentially, the normal battery voltage) for the Derbi vs. 15.3 volts for the vespa,
I brought the Derbi into my local Vespa dealer in Denver for troubleshooting and repair. Initial diagnosis was a bad stator, which they replaced with a new Vespa stator. After installation, additional testing also indicated a bad regulator, which they also replaced with a new Vespa regulator. So far, the diagnosis sounded reasonable, as they needed a functioning stator output before they could determine that the regulator was also bad.
When I called to see when I could pick up the bike (still in the shop, work will be completed today) the service manager said that I had installed the wrong type of battery in the bike. He said that because the battery compartment has a vent tube, the bike requires a maintenance-type battery, rather than the maintenance-free battery that I have currently in the Derbi (I've had several batteries over the life of the bike, and the last couple have been maintenance-free). When I explained that my current battery was working well (I keep it on a battery tender between rides), the fact that it was not the original maintenance-type battery should not make a difference. I asked that he measure the charging voltage at the battery while the bike was running (and presumably charging the battery after the repair).
I was told that the charging voltage at the battery with my current (maintenance-free) battery was about 13.4 volts with the bike running, but that the voltage using a maintenance-type battery that they substituted for testing was about 15 volts. He suggested that I replace the battery for the charging system to work properly.
As an engineer, this explanation makes absolutely no sense to me, and I declined the offer to sell me a new battery. If a battery is the correct voltage and amp-hour rating (and it is, according to the recommendations for this bike), it should make no difference whether it's a maintenance-free battery or not, and the charging system output should remain the same for either type of battery.
This is a reputable dealer (I bought my Vespa from them), but I'm losing confidence when I hear this kind of explanation.
Am I wrong or is there something I'm missing?
