Both the front and rear indicators on the right side of my Fuoco 500 are not working and neither does the light flash on the instrument panel. The left side works perfectly and flashes on the instrument panel. Filaments on both globes are intact. Your thoughts or input would be greatly appreciated. Thanks in advance.
I don't know if all those go through the same relay but could be turn signal switch. Have you tried your hazard lights?
Thank you for the sugestion but Hazard flashes on the left only so that rules out the indicator switch I guess.
Problem sorted.
Opened the indicator lens to find one of the two wires had come loose. Obviously forms a circuit so I'm sure even one fused bulb will take out both the front and rear indicators on that side.
Problem sorted.
All Content Copyright 2005-2025 by Modern Vespa. All Rights Reserved.
