I mounted one on my scoot's rear crash bar. Has 3 settings; slow swing L & R strobe, quick, and steady on.
I used it extensively for night commuting to work in the rain.
Uses 2 AAA batteries - on/off switch is on the side for easy access.
Only on the 2nd set of batteries after 5 yrs use.
Seals well, with rubber gasket - inside stays clean and dry in wet weather. Amazon.
It is amazingly bright! I used the slow L & R swinging strobe almost always.
