Hi folks,
Can someone tell me what the stud spacing is on your run of the mill 10" wheels?? I mean the distance from center running through the middle of each stud (I know this is probably obvious without me stating it, butcha never know??) I want to try and fab up a disc brake using a modified standard hub, basically the same as the attached pic, but Vespa obviously.
http://www.scooter-center.com/en/product/BGM7890BK/Disc+brake+BGM+PRO+Anti+Dive+Lambretta+LI+LIS+SX+TV+DL+GP+incl+caliper+black
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
Gonna have to say something about which Vespa. If you are talking classics such as the P/PX - you will do better in the "Not-so-modern" forum.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
The technical term for that is Bolt Circle, sometimes abbreviated as BC in some specs.
Bolt circle, nice one thanks for that mate. I ended up just finding a wheel rim and taking the specs from that. I was after a PX/etc type so next time I will ask in the not so modern forum, cheers
[ Time: 0.0080s ][ Queries: 3 (0.0022s) ][ live ][ 339 ][ ThingOne ]
