@luckymonkeygarage avatar
1977 Vespa P200E, 1974 Vespa Super 150
Can anyone out there shoot me some good photos of the wiring near the battery and fuse block? I have diagrams just need to have a good look at someone else's set up.
Thank you,
Rinaldi
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
What is it you're trying to figure out?
Need to clean it up. Want a stock look. Currently it runs but everything else doesn't work. Just cleaned up the wiring behind the headlight.
@rowdyc avatar
@rowdyc avatar
If you find a picture or don't find a picture you may want to convert to AC.
Scooterwest has a easy to follow video to do this:
https://www.youtube.com/watch?v=4ES6BxBUDcg
Good luck!
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
socalguy has 2 of those things, I'll bet he hooks you up if you are specific
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
The wiring on my 76 Super is a little different - only one fuse. I tried to take a pic but it's too tight and doesn't show much.
This should help:
Good info from all of you! Super grateful!
@subetherbass avatar
Dunno..
Insurance it...
Add an old-Skol ticking clock
Print a copy of above wiring diagram (black & white will be best)
Park it somewhere prominent
Go shopping
& once the bomb squad robot blows it up claim it on insurance?
This should help:
Which regulator is this? Is this the one that also goes on the Rally that is sold at Scooter West for over $200? If so can anyone suggest something less expensive?
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Yup, that's the one if you want to go stock. But there are other options.
BGM makes this 6v regulator/rectifier that I believe can be wired to work for your set up.
http://scooter-speed.com/voltage-regulator-bgm-6v-ac-dc-4-plug-dw-bgm6696/
Run your yellow wires from the stator to the AC IN connection on the regulator, the white-green from AC OUT, the positive from the battery and the red power wire to the ignition switch from the DC OUT terminal the regulator, black wire to ground, and either ground or float the white wire.
Would like to get a new fuse holder with cover. Any suggestions for 6 volt?
Any fuse holder will work, it doesn't care if it's 6V or 12V. Try Amazon.
So far this is what I've done. I put a fuse between battery and the AC out. You mentioned floating the white wire, but there's two? No mention of the green wire or what to do with the flasher wires.
Thank you all! Can't wait to get it out of the garage.
After looking at the original diagram I'm guessing the green wire gets a fuse and connects to the positive on the battery?
Is the connecting wire between the two yellow wires going into the regulator ok? It came that way in the box.
The old fuse block is all buggered up so I'm not using it.
What size fuses should I use?
SoCalGuy?
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Pm me. I'll walk you thru it.
[ Time: 0.0139s ][ Queries: 4 (0.0052s) ][ live ][ 343 ][ ThingOne ]
