Madison Sully wrote:
Stromrider wrote:
Your bike doesn't need to stand for too long before the fuel in the tank goes off. The components of the fuel start to separate out after just 5-6 weeks.
Not saying no here, but all of my 5 scoots started pretty much right off after being stored for almost 6 months over winter. Hard start first time out for two of them, sure, but everything fine after that first cold start.
I'm thinking valves.
Unlikely to be valves as tight valves will normally only affect hot running unless they are very very bad indeed. But, yes indeed Madison. Know what you mean. My bro in law has a tiger 800. He stores his bike for 6 months at a time each winter and contrary to most of us over here, rides just 1500 miles a year. I kinda tell him he should sell his bike to me at a knock down rate as he isn't using it enough...lol. Yet until this spring it always started fine over the last 4 years after storage. This year he encountered the rough starting and poor running, stalling not idling right etc, down on power problem. I took a look and with a torch you could see the sticky gum in the fuel tank. It's a brown reddish colour. I dosed it with Redex Fuel System cleaner and he rode the bike for a week and refilled with yet more Redex. It cured the problem. It ran very rough to start with as the Redex dissolved the gum and carbon in the engine. That's normal, but suddenly it ran real good with improved power and mpg's. He said it ran better than it had done for a couple of years. So couple of things. It depends on the type of gas in your bikes as to how quickly the individual components separate out. Even the octane rating alters the separation effect. It also depends how the bike is stored ie: in a warm environment or cold environment. It's also a mostly
cumulative effect, so if a bike is being used regularly but very short miles the fuel in the tank takes ages to be used up so the gas goes 'off' 'bad' or whatever you want to refer to it as. Gradually as the bike is used small amounts of the sticky gum starts lining the fuel system and injector, also reducing the amount of fuel that can pass through the pump and filter. It also starts to cover the inlet valves and seats lowering performance. All easily cleaned off with a fuel system cleaner. But may need a couple of tanks of fuel with cleaner to do it. If you do the same to your bikes it will likely make them go better all round! Good luck...
