Hi,
I'm having problems lately starting my 2006 GTS250ie, especially on cold morning. It won't start on the first try but on the second try it usually does. I have recorded the problem, but sometimes it's even worse than this:
https://www.flickr.com/gp/st-jean/158B2T
I have a new battery, I have replaced the faulty pump fuel, the spark plug has been changed about 2000KM ago and the valve adjustment has been done at about the same time.
Should I prioritize changing the spark plug wire and then cleaning the throttle-body air bypass? Or should I investigate something else?
Thank you for advises.
