monza wrote:
thats a decent oil...
Do you run it wide open at all? If not, then that can cause carbon to build up at a faster rate. Remember that you cant hurt it by running wide open. They designed it to run that way.
If the case above isnt true, then it sounds like it could be running rich. Put a new plug in and do a plug chop (run wide open all the way up to top speed, hit the kill switch at the same time as you let off the throttle, and stop as quickly as possible, pull the plug. Should be chololate-milk colored).
its still under warrantee right? have them look at it if you arnt sure.
I'm planning on buying a few new plugs. I'll try the plug chop. Is it okay to remove the plug when the motor is still hot?
Aside from the condition of the plug, the scooter really feels healthy. It's got quite a bit of balls for a 50cc. If I had never pulled the plug, I wouldn't have any reason for concern.
